Du verwendest einen veralteten Browser. Dieser kann eventuell diese oder andere Webseiten nicht richtig darstellen. Du solltest deinen Browser aktualisieren oder einen alternativen Browser verwenden.
FrageGet more power from 11441/ Mehr Leistung bekommen ab 11441
What's the Problem with your 11441? Or better ask where do you lack the power?
Might help if you tell us a little bit more about the work the Zetor has to do? It's maybe easier to give you adequate anwers then.
Hi I find the 11441 lacks pulling power.
This tractor can be doing silage, pulling 2300 gal slurry tank, 16tun dump trailer and a few other jobs. 11441 also goes dies down in revs when on dite feeder.
We have removed the egr valve. I was wondering how could you turn up the 11441 to get a small bit more hp
You might manipulate the fuel injection pump to get more hp.
But beware of the fact that you might damage the transmission if you use your tractor always on the limit. Also you are losing guarantee if you still have it.
Seems like your 120 hp tractor might be a bit small (and also light) for the things you want to drive with.
@leimarlene
Aaron möchte gern mehr Power aus seinem 11441 herausholen, er hat schon irgendwas an der ESP gebastelt.
Aber frieda rät ihn davon ab, da der Traktor zu klein, zu leicht ist und zu schwach ist, sowie der Antriebsstrang für mehr Power ungeeignet ist.
