Frage Zetor 6211 Speedometer
N
Nevin
Ireland
Eoghan
Zetor 6211
Hi all,
I am wondering with regards to the speedometer, when i push down key in normal position (no lights on) the speedometer goes up to between 10 and 15 km/h and then if i turn the key to turn on the lights it goes all the way to the end of the readings?
Is the normal - surely not ?
Any ideas, short to ground, poor connections ??
I'm quite sure they speedometer is original
Thanks
Nevin
Since we don't know what your electrical system looks like, little can be said. ;)
One thing is certain, however, it is not normal!
Take the circuit diagram and then first check the 3 or 4 cables between the signal generator and the speedometer. Also check whether there is a short to ground there.
Ok Joachim, I will try these things when I get a chance.
Thanks
In saying you don't know what my electrical systems looks like, is it pictures you need ? - under the dashboard ? :nolike
I don't think any cables have ever been replaced or any alterations to the wiring from standard:)
Also would you have a wiring diagram of a 6211 Joachim?
Thanks
Nevin
Do you have a wiring diagram of speedometer and signal generator ?
Thanks
christian_vogtland
N
N
Nevin
N
